It is currently Tue May 26, 2026 10:34 am
PostPosted: Sat Jan 17, 2009 7:50 pm
I have a '75 Scamp, slant 6/auto.
Basically, what cars/trucks should I be looking for to obtain the right bolt in parts? I wasn't sure if early A-bodies had different clutch pedal boxes, etc. What about Aspens/Volares?
I would also eventually want to put in a small block V8, do Aspen/Volare K-members differ from the earlier '70s models? What about earlier 60s models?
Thanks guys!
 Post subject: Only...
PostPosted: Sat Jan 17, 2009 10:54 pm
You are looking for a 1967-1976 A-body for your parts....
When you go V-8 you'll be swapping out a few minor linkage items (Z-bar, fork rod, etc...), also you can just buy the conversion motor mounts saving you the hassle of swapping in a 1973-1976 A-body K-member...
