| Exhaust manifold question https://slantsix.org/forum/viewtopic.php?t=33295 |
| Author: | NewSlanter [ Mon Jan 12, 2009 10:51 pm ] |
| Post subject: | Exhaust manifold question |
I was checking over my engine compartment today and noticed my exhaust heat valve was a little sticky. I fetched my trusty WD40 (I know, I know. Thanks in advance, Nat |
| Author: | 68barracuda [ Tue Jan 13, 2009 4:24 am ] |
OK OK OK I am going as fast as I can |
| Author: | NewSlanter [ Tue Jan 13, 2009 10:19 am ] |
I can't believe you can hear my whip cracking from all the way over there! |
| Author: | 65Dodge100 [ Tue Jan 13, 2009 10:39 am ] |
Can you thread them and put a little screw in the holes? |
| Author: | NewSlanter [ Tue Jan 13, 2009 10:43 am ] |
That's kinda what I was thinking. Only problem is the hole goes through and is met by the flapper shaft. I'm not sure how I'd thread the hole without scarring the shaft which could cause a whole new set of problems. |
| Author: | 65Dodge100 [ Tue Jan 13, 2009 12:42 pm ] |
| Author: | NewSlanter [ Tue Jan 13, 2009 8:41 pm ] |
Thank you sir. |
