| Don't want to spend the money, buuuuut... https://slantsix.org/forum/viewtopic.php?t=33307 |
| Author: | Jopapa [ Tue Jan 13, 2009 11:25 pm ] |
| Post subject: | Don't want to spend the money, buuuuut... |
I really like how this comes with the adapter and an adjustable pushrod to make it practically plug n' play, and the fact that it's aluminum as well. http://www.reillymotorsports.com/store/ ... 273&page=1 What're you guys' thoughts on Wilwood master cylinders, neverminding the price? |
| Author: | Jopapa [ Sat Jan 17, 2009 9:58 pm ] |
Hmmmm, no takers, eh? |
| Author: | gmader [ Sat Jan 17, 2009 10:08 pm ] |
what kind of brakes do you have? I think the bore size is going to be small for any disk brakes that you might use. |
| Author: | Jopapa [ Sun Jan 18, 2009 1:17 am ] |
Quote: what kind of brakes do you have? I think the bore size is going to be small for any disk brakes that you might use.
I'll be using the 11.75" discs with the larger bore calipers up front, and the stock drums in the back (still need to find out if I should go with the smaller bore wheel cylinders or if sticking with my stock cylinders and adding a proportioning valve in the rear brake line downstream of the distribution block would be the best way to go with bigger brakes up front). I was wondering about the MC's bore size myself. I would like a little less pedal effort, but I don't want it to travel all the way to the friggen firewall either. I'll be converting to manual brakes at the same time.There's also the 1 1/16" bore aluminum MC for manual brakes, but that still leaves me to having to source a manual brake pushrod. it does come with the adapter thought, which is a step in the right direction. Far less expensive too... What is the bore size of a factory '74 Duster disc/drum power MC anyway? |
| Author: | Rug_Trucker [ Wed Jan 21, 2009 7:08 am ] |
You need the "bling?" If not Eburg sells aluminum MC's for a good price from time to time. |
| Author: | Jopapa [ Wed Jan 21, 2009 8:10 pm ] |
Quote: You need the "bling?" If not Eburg sells aluminum MC's for a good price from time to time.
I guess bling factor is a small part of it. I do like the clean look of the Wilwood MC. I'll go for practicality over that, though, and for what the kit comes with from Bill (Reilly), it's still spendy, but makes for a great candidate, given that it has the adjustable pushrod and comes with the MC adapter.After talking to Bill over on bigblockdart, I think the 7/8" bore will be a good way to go with manual brakes, especially since I decided to go with just the late B-body single piston front calipers. |
| Author: | MichaelS [ Thu Jan 22, 2009 6:52 am ] |
Well, it dose look really cool but... $300!!. The mopar aluminum master and adapter can be done a lot cheaper. But it dose look cool. |
| Author: | Rug_Trucker [ Thu Jan 22, 2009 7:34 am ] |
Quote: Well, it dose look really cool but... $300!!. The mopar aluminum master and adapter can be done a lot cheaper. But it dose look cool.
Yep, if you want bling polish the aluminum one before installation! |
