Slant Six Forum https://slantsix.org/forum/ |
A-513 Conversion https://slantsix.org/forum/viewtopic.php?t=33371 |
Author: | wjajr [ Sun Jan 18, 2009 11:36 am ] |
Post subject: | A-513 Conversion |
I ran across this conversion for 1995 and older A-518 lock up overdrive transmissions not needing electronics that looks interesting: http://www.transmissioncenter.net/SwapInformation.htm |
Author: | 66aCUDA [ Mon Jan 19, 2009 6:09 am ] |
Post subject: | |
But is there a 518 to slant 6 adaptor??? Frank |
Author: | wjajr [ Mon Jan 19, 2009 9:54 am ] |
Post subject: | |
Don't know. Dose 727 & 518 use the same case? |
Author: | Dart270 [ Mon Jan 19, 2009 10:01 am ] |
Post subject: | |
A-engine 727 and 518 and 500 and 904 trannys all have same bellhousing pattern. Some minor diffs on earlier trannys you can correct (pretty sure) with a hand drill, or leaving out a bolt or two. Lou |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
