It is currently Thu Jun 18, 2026 3:42 pm
PostPosted: Sat Jan 24, 2009 5:27 am
Well I got the rear suspension changed over in my Volare.Everything fit good.I did have to have some steel spacers made for the center bolts.The holes in the axel housing were 1 5/8 and the center pin was 1/2 inch.The up side is I can have offset bushings made if I have to correct the thrust angle,I won't know that until I reinstall the motor and have the vehicle realigned.Checked the ride height and came up the same as the stock springs and seems a little stiffer.I was concerned about that going from multi-leaf to mono leaf.Can't want to see how it drives and more importantly how it hooks up. :D
I'll post more photos asI continue on trying to finish up this car.
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Mon Jan 26, 2009 9:07 am
Looks like a nice setup. Thanks for the pics!
PostPosted: Mon Jan 26, 2009 6:33 pm
Has the Green Team seen this?
