| Wix 51806 consistency https://slantsix.org/forum/viewtopic.php?t=33573 |
| Author: | Pierre [ Sat Jan 31, 2009 11:43 pm ] |
| Post subject: | Wix 51806 consistency |
I bought 6 or 8 of these from filter1.com some time ago. It seems like I'm having drain back issues with every other one. Some, after the initial startup, would give pressure a second after starting even after sitting 2 days over a weekend. The one I have on there now, after the weekend, may take 15+ seconds of cranking before pressure builds and I let it start. What gives? Are they really that sensitive to how tight they are installed, or did I just get some from a funky batch? Nothing else has changed. |
| Author: | SlantSixDan [ Sun Feb 01, 2009 12:04 am ] |
It's often difficult or impossible to build oil pressure sufficient to turn off the light just by cranking on the starter. How quickly does the light turn off if you go ahead and let it start? |
| Author: | Pierre [ Sun Feb 01, 2009 12:13 am ] |
Maybe with a stock starter - the mini starter winds 'er up pretty good. I can get enough pressure off the starter alone without running (ignition/efi is on a separate switch from the key) to turn off the light after cranking for 15+seconds. I haven't waited too many times for the light to go off on its own without pre-cranking first. Maybe 10 seconds? If I forget to pre-crank, I get spooked when the red light is staring at me and engine is running so I kill it, crank, then start again. Maybe 10 seconds isn't that long. I just don't understand how it can vary 1s from one filter to 10s of the other. |
| Author: | Miser [ Sun Feb 01, 2009 12:26 am ] |
i got one from them and my truck would clatter on startup after sitting for a couple days, hasn't happened w/ the one from napa. |
| Author: | Eric W [ Sun Feb 01, 2009 1:48 am ] |
Over the course of the last couple of years, when I've changed the Napa Gold filters during an oil change, I've had two of them (one short and one large filter) with no oil in them. Anti drain back valve not doing its job? Have not had it happen recently, though thats one of the reasons I try to use Purolator filters (hard to find around here...only Pep Boys in Everett or Fred Mayer carry them). Never had an issue with them. |
| Author: | MitchB [ Sun Feb 01, 2009 4:28 am ] |
FYI, the Motorcraft FL1-A filters have an anti-drain valve. I have never had a problem, get immediate oil psi on cold starts and I do not have a pump stand pipe. Mitch |
| Author: | Aggressive Ted [ Sun Feb 01, 2009 9:24 am ] |
I use the NAPA 1806 version also. With 0-30W Mobile 1 on a cold start up it takes less than 5 seconds to hit 50 pounds oil pressure. That's typical even on 15 degree mornings. |
| Author: | Jester [ Sun Feb 01, 2009 12:28 pm ] |
12 bucks for a Napa 1806 filter up here. Today would be a good day to warm up the motor, drain the old oil, run some fresh oil through it, drain that and then install the 1806 with Synthetic, and see how it works. The motor in the Dart is nasty, I may run Lucas or seafoam through it. |
| Author: | Pierre [ Mon Feb 02, 2009 2:32 am ] |
I guess I just got a few bad ones. I still have some left. Hopefully this is isolated and wix quality isn't slipping. |
| Author: | Rug_Trucker [ Mon Feb 02, 2009 6:48 am ] |
Quote: 12 bucks for a Napa 1806 filter up here. Today would be a good day to warm up the motor, drain the old oil, run some fresh oil through it, drain that and then install the 1806 with Synthetic, and see how it works.
Isn't Seafoam a combustion chamber cleaner? I think leaving the crud where it sits is best. Don't want it circulating around, or plugging the pickup. The motor in the Dart is nasty, I may run Lucas or seafoam through it. Diesel oil has tons of detergants in it. |
| Author: | Jester [ Mon Feb 02, 2009 10:21 am ] |
I was thinking a litre of tranny fluid run through for about 100 miles would clean things out pretty good. I might try the Lucas fuel system additive, gotta get some of the carbon deposits burned out of the combustion chamber. #1 and 6 are carbon fouled, while 2-5 are fine. Brand new NGK's, wires, and entire electronic ignition. |
| Author: | KBB_of_TMC [ Mon Feb 02, 2009 11:18 am ] |
I seem to remember that a Mopar oil pressure switch opens at 2psi or so... I had a low-oil-pressure '74 Mopar with both the stock light and an aftermarket mechanical gauge on it and I seem to remember that by ~3 psi the light when out. I've had several of the oil pressure switches go bad on my /6 - they'd leak inside and turn the light on when they pressure was much higher (>10psi), even though I used the correct special socket to install them. |
| Author: | Pierre [ Mon Feb 02, 2009 10:23 pm ] |
I have the pump tee'd into the stock switch and a sensor for aftermarket gauge. I suppose they both could of went bad at the same time but I don't know... I'm due for an oil change. I'm starting to ponder mounting the filter "right side up" with those adapters that are commonly available and running hoses..... I hope this is just a freak thing and not wix slipping. |
