| Anyone want to take a guess? https://slantsix.org/forum/viewtopic.php?t=3358 |
| Author: | Jerry [ Thu Mar 14, 2002 5:14 pm ] |
| Post subject: | Anyone want to take a guess? |
225 /6 with flat top pistons 30 over on a stock rebuild, felpro permatorque head gasket and a 1975 head with 58.5 cc combustion chamber. Block is uncut. What's your best guess of my compression ratio? Jerry roxnjer@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Mar 17, 2002 9:21 am ] |
| Post subject: | Re: A "Dreamwheel" guess |
My "Power-speed calculator" comes up with 89 cc total TDCC volumn for 8 to 1 compression. The big unknown here is the piston's compression distance, I based my calc. on .14 negative. (down in the bore) This needs to be measured so we can move from *guess* to actual compression. DD Quote:
: 225 /6 with flat top pistons 30 over on a stock : rebuild, felpro permatorque head gasket and : a 1975 head with 58.5 cc combustion chamber. : Block is uncut. What's your best guess of my : compression ratio? : Jerry |
