| update on 63 valiant ( good news!) https://slantsix.org/forum/viewtopic.php?t=3359 |
| Author: | Larry Laduc [ Thu Mar 14, 2002 7:13 pm ] |
| Post subject: | update on 63 valiant ( good news!) |
Ok, i got the valiant running! It turns out the distributor was set incorrectly, the rotor was pointing towards the fenderwell and i repositioned it and it fired up! i took off the valve cover and it was really sludged up. I went and got a gasket, and adjusted the valves correctly and that got rid of the idle problem, and it also fixed a miss in the engine. it runs really smooth and i can't wait to take it up and down the street tommorrow and see how the transmission shifts etc. Thanks for all your support and help. I am looking to add a little power to it so i might add a super six later on down the road. ksjo923@hotmail.com |
| Author: | Doc. [ Fri Mar 15, 2002 12:22 pm ] |
| Post subject: | Re: 63 valiant ( good work) |
Thanks for the up-date, glad to hear you "stuck with it" and got the car running well. DD Quote:
: Ok, i got the valiant running! It turns out the : distributor was set incorrectly, the rotor : was pointing towards the fenderwell and i : repositioned it and it fired up! i took off : the valve cover and it was really sludged : up. I went and got a gasket, and adjusted : the valves correctly and that got rid of the : idle problem, and it also fixed a miss in : the engine. it runs really smooth and i : can't wait to take it up and down the street : tommorrow and see how the transmission : shifts etc. Thanks for all your support and : help. I am looking to add a little power to : it so i might add a super six later on down : the road. |
