| A-Body 8 3/4 https://slantsix.org/forum/viewtopic.php?t=3364 |
| Author: | 63GT [ Sun Mar 17, 2002 3:38 pm ] |
| Post subject: | A-Body 8 3/4 |
Good score or what? I just picked up an 8 3/4 housing,two sets of small bolt axles,open 741 center,new in box Detroit Locker#187sl-14a,new in box Precision gear 4.10 gear set and a complete 8 1/4 open rear assembly out of 72 Demon. all for 550.00. My question is,will the Precision gearset#C8-410fine fit the 741 case? Thanks,Drew MoparBrat63@aol.com |
| Author: | Doc. [ Mon Mar 18, 2002 10:30 am ] |
| Post subject: | Re: A-Body 8 3/4 |
: Good score or what? I just picked up an 8 3/4 : housing,two sets of small bolt axles,open : 741 center,new in box Detroit : Locker#187sl-14a,new in box Precision gear : 4.10 gear set and a complete 8 1/4 open rear : assembly out of 72 Demon. all for 550.00. My : question is,will the Precision : gearset#C8-410fine fit the 741 case? : Thanks,Drew Good score, Measure the pinion stem size and that will tell us what it will fit. The 741 housing takes a 1 3/8 pinion stem, the 742 takes a larger 1 3/4 stem, if it has a taper to the stem with the large section @ 1 7/8, it is for the 489 case. DD |
| Author: | 63GT [ Mon Mar 18, 2002 4:57 pm ] |
: Good score, : Measure the pinion stem size and that will tell : us what it will fit. The 741 housing takes a : 1 3/8 pinion stem, the 742 takes a larger 1 : 3/4 stem, if it has a taper to the stem with : the large section @ 1 7/8, it is for the 489 : case. : DD Thanks Doc,Well..It's the tapered stem with the large end being 1 7/8 so I'll have to either find a 489 case or buy a new set of gears.Bummer!But I will have to wait a litte while for this is a budget build-up and I just bought one of those ebay cams from koller dodge. Thanks,Drew 63GT MoparBrat63@aol.com |
| Author: | Doc. [ Tue Mar 19, 2002 4:40 pm ] |
| Post subject: | Re: A-Body 8 3/4 "pumpkin" |
: Thanks Doc,Well..It's the tapered stem with the : large end being 1 7/8 so I'll have to either : find a 489 case or buy a new set of : gears.Bummer!But I will have to wait a litte : while for this is a budget build-up and I : just bought one of those ebay cams from : koller dodge. Good thing is that the 489 case is the "later unit and still pretty easy to find "cheap". I can grab a center section out of a junk yard for appx $35.00 and sometimes less at swap meets. In the past I have had the "crush sleeve" tapered pinion 489 units loose pinion bearing pre-load if really "beat-on", like with a big block or 4-speed but these days the rear-end suppliers have a crush sleeve eliminater spacer, this allows the 489 case to be set-up with shims, just like a 742 unit, this makes for a super strong center section. DD |
| Author: | 63GT [ Wed Mar 20, 2002 3:28 am ] |
: Good thing is that the 489 case is the : "later unit and still pretty easy to : find "cheap". I can grab a center : section out of a junk yard for appx $35.00 : and sometimes less at swap meets. : : In the past I have had the "crush : sleeve" tapered pinion 489 units loose : pinion bearing pre-load if really : "beat-on", like with a big block : or 4-speed but these days the rear-end : suppliers have a crush sleeve eliminater : spacer, this allows the 489 case to be : set-up with shims, just like a 742 unit, : this makes for a super strong center : section. : DD Thanks again Doc, I will do that,go boneyarding in hopes to find one.If no luck, I'll find one on Moparts hopefully close to me. And I think I will hold on to the 741.Maybe build another rear in a couple years. I'm getting close to having car ready for this summer although, the minor body work will have to wait for next year. Thanks, Drew MoparBrat63@aol.com |
