It is currently Thu Jul 09, 2026 12:32 pm
PostPosted: Sun Feb 08, 2009 12:23 pm
Took a customer motor apart yesterday that had "issues". Among other things I found a badly worn oil pump gear. It was sharp enough to cut you, but had not completely failed. Cam was a Comp Extreme that I had used without problems in my motor for quite a while. Cam appears undamaged. Motor had less than 200 miles on it. :shock:
Pump was an MP high pressure/volume pump that I had advised the customer against using, but he insisted.
Other issues are under investigation, but seem to be fitting a pattern of motor failures in the last year by many different builders.
Motor will go back together with my personal favorite, the Vatozone 5 bolt pump.
 Post subject: Keep us posted...
PostPosted: Sun Feb 08, 2009 1:38 pm
Thanks for the heads up, I haven't had problems with the Comp Cam oil gear yet on either of my rigs...but I also use the 'regular' Melling Oil pump.
Thanks for the heads up.
PostPosted: Sun Feb 08, 2009 2:04 pm
Warranty? Denied. :wink:
Users browsing this forum: Bing [Bot] and 6 guests
