It is currently Sat Nov 21, 2026 11:47 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Wed Mar 20, 2002 5:42 pm
58.5 cc head, 27cc above piston, gray felpro 38 thou? thick perma torque head gasket.
What is my compression ratio?
Jerry
roxnjer@aol.com
 Post subject: Re: best guess #2
PostPosted: Wed Mar 20, 2002 8:44 pm
: 58.5 cc head, 27cc above piston, gray felpro 38
: thou? thick perma torque head gasket.
: What is my compression ratio?
: Jerry
Most head gaskets are .045, some are .038 and others .020 (steel shim type)
58.5 + 27 + 6 (.038) = 91.5 cc
On a .030 o/s "228" CID that gets you a 7.85 c/r
(If these are actual readings, mill the head or use a Turbo)
A Compression Worksheet example
Users browsing this forum: Amazon [Bot] and 5 guests
