| Performance estimate? https://slantsix.org/forum/viewtopic.php?t=3379 |
| Author: | Brian McMath [ Wed Mar 20, 2002 7:05 pm ] |
| Post subject: | Performance estimate? |
I just completed the buildup of my old slant, and I was wondering what kind of performance I could expect from it (I live at sea level). Mods include: Aluminum 2 bbl intake w/ Holley carb .030" overbore .005" head milling Stock-spec camshaft 3-angle valve job and update for unleaded gas All new internals Full 2 1/4" single exhaust High flow air filter I'm a novice engine builder, so any help you veterans can give would be great! bribri15@umail.ucsb.edu |
| Author: | Ron [ Thu Mar 21, 2002 5:29 pm ] |
| Post subject: | Re: Performance estimate? |
Brian if your car is a driver with no weight loss and has a stock rear gear typical 2.93 or 3.23 you can expect about 18.65 in the 1/4 and about 12.00 in the 1/8 tell me if i am close go blow there doors off. Thanks Ron rpracing@catt.com |
| Author: | Brian McMath [ Fri Mar 22, 2002 10:36 am ] |
The best I've ever got it to is low 20s. But I'm a total greenhorn when it comes to the art of draggin'. That was with me shifting the 904 manually too. But I'm sure if I knew what I was doing, your estimate wouldn't be far off at all. Thanks! bribri15@umail.ucsb.edu |
