It is currently Sat Jul 04, 2026 2:11 am
 Post subject: Spring on Fuel Pump?
PostPosted: Sat Feb 21, 2009 2:08 pm
I just got a fuel pump from Napa (part no. M60576) The fuel pump that I removed has a spring on the arm. The new pump has no spring, nor does it have nipples to hold a spring in place, so I can't just put the old spring on the new pump. Did I get the wrong part?
God took you away, then brought you back to me.
PostPosted: Sat Feb 21, 2009 2:49 pm
No, you've found yet another example of "decontenting" (cheapening/crappification) by the MBA knownothings who now run most auto parts companies. :roll: It'll work, it just may be slightly noisier.
PostPosted: Sat Feb 21, 2009 2:52 pm
Dan is correct. I just replaced my fuel pump with the exact one you mentioned,and its actually quite a bit noisier.I can here it at idle sometimes,and sometimes not. :roll:
PostPosted: Sun Feb 22, 2009 5:07 am
Yup AND I now carry a spare one in my trunk....ASK WHY !!!!! :evil:
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Feb 22, 2009 12:57 pm
WHY??? :shock:
PostPosted: Mon Feb 23, 2009 5:24 am
63 miles later I had to put the old one back on to get me to a NAPA. Of course then I had to change the oil again, twice. (gas in oil) I now carry a spare. :?
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
