It is currently Sat Jun 13, 2026 1:44 pm
PostPosted: Tue Mar 03, 2009 8:06 am
Soon the head will be carted off to the machine shop to cut in new over sized valves (1.70", 1.44") from stock. Do I need to install new hardened seats, or is there enough depth of hardness to just enlarge the stock opening?
PostPosted: Tue Mar 03, 2009 8:08 am
I put hardened in the Exhaust only.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 03, 2009 8:52 am
"I put hardened in the Exhaust only"
+1
obliquely-inclined state of mind
PostPosted: Tue Mar 03, 2009 9:23 am
+2. Hard seats in the exhaust locations.
PostPosted: Tue Mar 03, 2009 9:28 am
The hardening in the stock exhaust valve seats is often quite shallow. A stock valve job or two and the hardening is usually gone. Hard exhaust seat inserts are the way to go.
PostPosted: Tue Mar 03, 2009 4:31 pm
Kin'dah figured that, but wanted to check in with the Gurus. Thanks
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Chris6064 and 1 guest
