It is currently Tue May 19, 2026 6:13 pm
 Post subject: converter stall?
PostPosted: Sat Feb 21, 2009 9:02 am
Does anyone know what the stock stall is on a /6 converter? It seems I,m getting conflicting information from my parts suppliers :roll: what I,m saying is the information says 1800-2100 rpm but thats only 100 more than a v8 and in my parts book the converter number is the same for a /6 -v8 . and some older trans builders think that the stall on the 6 was 300 or so higher then the v8?.
I installed a "high stall " on my truck last year, that is supposed to be 400 higher than stock and actually it stalls at 2000-2100.what gives?
Nick
86 d150 turbo /6.
PostPosted: Sat Feb 21, 2009 1:40 pm
The converter for the Slant and small block are in fact the same converter. A normal one will stall around 1600-1800 behind a stock Slant, slightly higher behind a 318.
A converter will never stall higher behind a Slant than it will a 318, unless the Slant is pretty well modified.
Buying an "off-the-shelf" high stall converter is always a crap shoot at best.
