| Clutches & Safety Blankets https://slantsix.org/forum/viewtopic.php?t=3389 |
| Author: | Rick [ Sat Mar 23, 2002 6:59 am ] |
| Post subject: | Clutches & Safety Blankets |
Hi Doc, Has anyone out there ever thought of using an automatic transmission safety blanket on a 4-speed Bellhousing for some extra protection. As we talked before, having one clutch explosion and walking away unhurt is good, but probably lucky!! With no bolt-on scattershield available I was wondering if the blanket may give some added protection. Your thoughts?? Would it be strong enough?? Waste of time?? Thanks, Rick rcovalt@innernet.net |
| Author: | GTS225 [ Sat Mar 23, 2002 7:59 am ] |
| Post subject: | Re: Clutches & Safety Blankets |
: With no bolt-on scattershield available I was : wondering if the blanket may give some added : protection. Your thoughts?? Would it be : strong enough?? Waste of time?? ************************************************* Rick, I suggest that ANYTHING that can be done to reduce/eliminate possible projectiles from entering the passenger compartment is a good thing. While a trans blanket might be a bit pricey, it would at least slow down the pieces. You might want to check with the mfgr. and ask thier opinion concerning use for a clutch rather than an auto. Just remember.....Don Garlits lost half his right foot in a clutch explosion; hence we now have rear-engine TF dragsters. Roger GTS225@aol.com |
| Author: | Rick [ Sat Mar 23, 2002 12:42 pm ] |
: : ************************************************* : Rick, I suggest that ANYTHING that can be done : to reduce/eliminate possible projectiles : from entering the passenger compartment is a : good thing. While a trans blanket might be a : bit pricey, it would at least slow down the : pieces. You might want to check with the : mfgr. and ask thier opinion concerning use I'm watching one on E-Bay at $75.00 so it may not be too expensive to give it a try. Rick : for a clutch rather than an auto. : : Just remember.....Don Garlits lost half his : right foot in a clutch explosion; hence we : now have rear-engine TF dragsters. : : Roger rcovalt@innernet.net |
