It is currently Fri Jul 03, 2026 4:02 am
 Post subject: nitrous fuel system
PostPosted: Fri Feb 20, 2009 5:00 pm
I building my slant this winter and i plan on running some nitrous. I bought a NOS plate system used, and it will probley eventually see some 150hp hits. I was wondering what you guys reccomend for a fuel system? I have read on here that doc reccomends a separate fuel system just for the nitrous. What is involved with that? a separate fuel pickup in the tank, or just a "t" in the line were one line goes to the fuel pump for the nitrous and one for a fuel pump that goes to the carb?
PostPosted: Fri Feb 20, 2009 6:04 pm
For a single system that will never see more than a 150 hit I would simply run a Holley Blue pump or something similar with the lines split at the regulator. The carb and nitrous will both run on 5.5-6 psi of fuel pressure, and a blue pump will supply more than enough volume for both. :shock:
PostPosted: Fri Feb 20, 2009 9:17 pm
so with a blue pump, i will still use a stock pick up in the tank right? Will i have to change my line over to AN from the tank or can i keep the stock steel line?
PostPosted: Sat Feb 21, 2009 3:18 am
I used the stock pickup and ran a 3/8" steel line to the regulator. I ran the line on the driver's side of the car and put the regulator on the driver's side fenderwell under the hood to make plumbing it less of a nightmare. :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
