| Rocker Arm Spacers https://slantsix.org/forum/viewtopic.php?t=3391 |
| Author: | Eric W [ Sat Mar 23, 2002 1:15 pm ] |
| Post subject: | Rocker Arm Spacers |
I was wondering if the spacers that go between the rocker arms on the rocker shaft are available new anywhere. My rocker arms are moving for and aft quite a bit with the engine running. Thanks for any help! Eric W My Big B ecwfury@webtv.net |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Mar 24, 2002 7:28 pm ] |
| Post subject: | Re: Rocker Arm Spacers |
: I was wondering if the spacers that go between : the rocker arms on the rocker shaft are : available new anywhere. My rocker arms are : moving for and aft quite a bit with the : engine running. Thanks for any help! : Eric W Rocker Arm Specialists (RAS) have washer shaped "shims" you can use. I grab a bunch of the wider center spacers (wrecking yard candy) and I grind them down to fit each position. DD |
