It is currently Fri Nov 29, 2024 12:56 pm
PostPosted: Tue Feb 24, 2009 7:25 pm
I just rebuilt my 1973 Holley 1920 using Walker kit 15519A. According to the factory service manual, page 14-13, has instructions for reinstalling the choke vacuum diaphragm. The instructions say to determine if the diaphragm has internal leaks to depress the diaphragm stem and then place a finger over the vacuum fitting to seal the opening. Release the diaphragm stem and if the stem moves more than 1/16th inch in ten seconds, the leakage is excessive and the assembly must be replaced. I did this test and the stem moved more then 1/16th inch very quickly. My rebuild kit did not come with a choke vacuum diaphragm. Can they still be bought?
PostPosted: Tue Feb 24, 2009 7:47 pm
Yep, they can still be had new - if you strike out locally, send me a PM; I have several new ones on the shelf.
PostPosted: Wed Feb 25, 2009 8:54 am
If you have an Auto Zone close by, try there. That's where I found one for my Carter BBD 2-bbl.
Roger
Users browsing this forum: Semrush [Bot], slantzilla and 10 guests
