oil pickup tube
https://slantsix.org/forum/viewtopic.php?t=34053
Page 1 of 1
Author:  rdcamit [ Sun Mar 01, 2009 1:43 pm ]
Post subject:  oil pickup tube
Good afternoon to all,
I would like to know of any tricks to get the oil pump pick up tube removed from the engine. I have teh oil pan off and the pick up tube looks clogged and want to remove it to try and clean it. the engine itself is spotless I just picked up this car and the owner told me it was a remanufactored block which it looks like zero miles on the enging but the oil pick up screen is filthy and looks clogged so I want to remove it and clean it.
Any help would be great.
Thanks
Ron
Author:  Reed [ Sun Mar 01, 2009 1:49 pm ]
Turn the tube counterclockwise. Be prepared to rotate the crank to clear the tube.
Author:  rdcamit [ Sun Mar 01, 2009 2:31 pm ]
I've tried that I even tried with a pipe wrench on it and its not moving, and I dont want to brake it, any other ideasto get it to break loose
Author:  Eric W [ Sun Mar 01, 2009 2:52 pm ]
Hit it with a rubber mallet. Counter clock-wise.
Author:  rdcamit [ Sun Mar 01, 2009 3:14 pm ]
Thanks
I got a bigger pipe wrench and a long pull bar and got it to break loose. I knew I could get the advise I needed on this site.
