| 9" or 10" ? https://slantsix.org/forum/viewtopic.php?t=34058 |
| Author: | 75dartcustom [ Sun Mar 01, 2009 7:22 pm ] |
| Post subject: | 9" or 10" ? |
How do I measure to see what size drums I have on my 1974 Dart Custom? I'm trying to figure out if I have tens in back. I plan on putting disc brakes on the front and the 10" rear, disc front combo I had on my 75 worked great. If I have 9" rear drums, would you recommend replacing them with 10s? Thanks M |
| Author: | Reed [ Sun Mar 01, 2009 7:36 pm ] |
| Post subject: | Re: 9" or 10" ? |
Quote: How do I measure to see what size drums I have on my 1974 Dart Custom? I'm trying to figure out if I have tens in back.
Remove one tire from the rear axle and see what MAX DIA. is cast into the drum. That will tell you your drum size.Quote: I plan on putting disc brakes on the front and the 10" rear, disc front combo I had on my 75 worked great.
Upgrading to larger brakes is always a good idea.
| Author: | dakight [ Mon Mar 02, 2009 4:00 am ] |
You can measure the inside diameter of the drum with a ruler or measuring tape. |
