It is currently Fri Jun 05, 2026 6:42 pm
 Post subject: Wanting a sway bar
PostPosted: Wed Feb 11, 2009 6:42 am
I put disc brakes on my 63 valiant they came off a 75 dart The calipers mount in the front of the roter, now I'd like to add a front sway bar I call up the company to see about the sway bar they tell me that they will not work and pretty much hung up on me with out saying as much as goodbye :? what are my options
PostPosted: Wed Feb 11, 2009 8:38 am
You might be able to swap the calipers side to side and mount them to the rear. I'm not sure what all needs to be swapped around but I believe others have done it.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Feb 11, 2009 8:40 am
Yes. The spindles can be swapped sides making the calipers mount on the rear. Back when I had a 66 Barracuda Formula S ( :cry: ) I wanted to keep the factory sway bar and install disc brakes. i did the research and determined that the spindles could be swapped sides, the calipers would move to the back of the spindle, but I would have to use a long brake rubber line such as one from a 80 Volare.
PostPosted: Sat Mar 07, 2009 5:51 am
Did you contact Firmfeel? They have always been more than helpful whenever I call. I have the rotors on the fornt of my '70 e-body and the swaybar fits with no problems.
At one point, before I decided I wasn't able to get the correct brake hoses, I had the calipers mounted on the front of my '68 a-body and everything fit fine with the Just Suspention swaybar on it. It's the swaybar that uses the lower bolt on the front shock to attach the swaybar mount. Firmfeels has better mounting brackets for serious track use, but the Just Suspention one works beautifully for spirited road driving.
1968 Plymouth Barracuda Convertible Super six
PostPosted: Sat Mar 07, 2009 5:54 am
I used a PST bar with no problems. Some fabrication indicated for Early As....
