It is currently Sun Jun 07, 2026 8:21 am
 Post subject: bench bleeding.
PostPosted: Sun Mar 08, 2009 3:42 pm
OK guys, bear with me on this. I've heard the term "bench bleeding". What does it mean and how do you do it?? I've got a new master cylinder, sorry, I did not upgrade, it was an Ebay thing and the price was right. I know, I've heard all the rights and wrongs but for right now I'm sticking to original. How do you bleed the master on the bench with a minimum of fluid loss??
Next winter I'm going to do upgrades, really. I'm starting to save right now. Social Security doesn't go far.
Thanks.
Joe
PostPosted: Sun Mar 08, 2009 5:00 pm
First thingh you need is a bleeder kit, which will consist of a couple plastic fitting that screw into the master and a couple pieces of vinyl line that route back into the reservoir.
Clamp the master in a vise, install the fittings and lines, fill the master with fluid, and pump the piston until all the air bubbles disappear. :D
I leave the bleeder fittings in the master while I install it to cut down on mess.
PostPosted: Sun Mar 08, 2009 6:26 pm
I'm scared because I may have it. I've got a kit that is supposed to fill the master cylinder from the wheel that is the frurthest away. It's got a bunch of extra pieces and parts. I'll have to take a look at it tomorrow.
Thank you.
Joe
PostPosted: Sun Mar 08, 2009 8:12 pm
You could also bolt it into the car and bleed it using the pedal. Just saves a bit of work.
PostPosted: Sun Mar 08, 2009 9:00 pm
Bench bleeding only removes the air from the master cylinder bore. You will still need to do a final bleeding of all 4 wheel cylinders after you get the master back on the car.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Mar 09, 2009 2:54 am
Thanks all, I think I'm on the right track now. Since this is a Calif. car I'm going to assume that all the wheel bleeders are going to work the way they are supposed to. If it were a Maine car it would be a completely different story.
Thanks again.
Joe
PostPosted: Mon Mar 09, 2009 3:23 am
But then it wouldn't be "bench" bleeding, would it? :D :D :D
PostPosted: Mon Mar 09, 2009 4:31 am
Read here
See here
PostPosted: Mon Mar 09, 2009 5:39 am
Good article on bleeding and good tunes on the Itube
Thanks.
Joe
PostPosted: Mon Mar 09, 2009 9:22 am
Technically no, but I still call it bench bleeding, because I like to party :lol:
PostPosted: Mon Mar 09, 2009 9:41 am
...I thought it was like bench racing...are we bench bleeding yet? :?
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Mon Mar 09, 2009 10:17 am
Bench bleeding was what I did when I removed the tip of my finger with a veneer knife.......
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Mon Mar 09, 2009 10:25 am
Mandolin for me. Damned homemade potato chips.
PostPosted: Mon Mar 09, 2009 3:06 pm
Thank you two for sharing that. Who said we can't have fun here???!! I hope it wasn't the whole tip?? How were the home made chips after all that??? That's a serious learning curve and why do I feel like I've got a home here?? I'm finally with My People!!!!
Joe
PostPosted: Mon Mar 09, 2009 9:50 pm
Joe
Yep, 'bout a dime sized chunk. Completely grew back, fingerprint included too. Threw out that batch, but I made more later and they came out really good...
