hamonic balancer
https://slantsix.org/forum/viewtopic.php?t=34224
Page 1 of 1
Author:  kman [ Wed Mar 11, 2009 7:13 am ]
Post subject:  hamonic balancer
putting this back on But do not have access to the install tool. would a 4x4 and a hammer work or would this jamb the internals...?
Author:  6shotvanner [ Wed Mar 11, 2009 7:22 am ]
Don't do it,it's hard on the thrust/main bearing.I forget the bolt size right now but you can use a longer bolt with washers to install.Someone will chime in with the bolt size I'm sure.
Author:  SlantSixDan [ Wed Mar 11, 2009 7:42 am ]
Don't hammer or whack the damper, it'll break and damage stuff. Use a ¾"-16 × 2¼" bolt and appropriate washer to draw the damper onto the crank snout. You can leave the bolt in place once it's installed.
Author:  6shotvanner [ Wed Mar 11, 2009 10:38 am ]
I'm one of the few whose slant has a bolt from the factory maybe it was a truck thing, anyway; My balancer wouldn't go on far enuf to start stock length bolt so I picked up a 3" long bolt to get it started then switched to stock bolt/washer and seated the balancer.Just info for if it happens to you. 8)
Author:  kman [ Wed Mar 11, 2009 4:00 pm ]
Post subject:  had a feeling
thanxs thought it would be a bad Idea to hit the balancer, did pick up the right diameter bolt and will work on it thursday. thanxs again. will let you know how it turns out.
Author:  kman [ Thu Mar 12, 2009 9:45 am ]
Post subject:  somebody helped me....
when I wnet to the auto parts store, a Friend.....(%#!@) attempted to put on the harmonic balancer with the 4x4 and a hammer. Do I have to replace the main cap bearings now?
all good deeds don't go unpunished.
Author:  SlantSixDan [ Thu Mar 12, 2009 9:56 am ]
Post subject:  Re: somebody helped me....
Oh, great. Did this "friend" have permission to fool with your car while you were away?
How hard did he try, and how big a hammer did he use (and was he successful)?
(Psst…I sent you a PM the other day - please check your Private Messages inbox.)
Author:  Doc [ Thu Mar 12, 2009 10:03 am ]
Time to check the crankshaft "end-play" measurement.
Here is one of many webpages discribing the check:
http://members.rennlist.com/v1uhoh/cranksha.htm
Author:  kman [ Thu Mar 12, 2009 10:18 am ]
Post subject:  (#@!%)
its not all the way on, but its not coming off with out a puller. and a 5lb hammer. So it sounds like I have to tear the motor, lower end apart again, and get a new oil pan gasket, which is cheaper in the long run.
Author:  Doc [ Thu Mar 12, 2009 10:35 am ]
Be sure to use the correct puller, one that bolts to the center hub.
Author:  kman [ Thu Mar 12, 2009 10:41 am ]
Post subject:  puller
I have that, and the info about the measuring is great, but I have no flywheel on the end of the motor. how else would I check, or is it beyond checking.
Author:  Doc [ Thu Mar 12, 2009 10:46 am ]
Use the rear crank flange or the flex plate.
I use a dial indicator with a magnetic base and can set that onto either end of the crank to do the check.
Author:  Dart270 [ Thu Mar 12, 2009 10:53 am ]
I advise you not to tear your engine apart just because of this. Just check endplay and reinstall the damper. 999/1000 times you will not hurt the thrust bearing, is my estimation.
I have beat on quite a few dampers with wood and a hammer with only one damper damaged (1st one) and NEVER any crank damage. You just have to be careful and not cock the damper on the snout of the crank - evenly tap it on, rotating your taps around the snout as you go.
FYI, Cameron Tilley, world ruler of Slant 6 horsepower, also beats his on with a hammer and block of wood. I saw him do two that way...
I have installed a few with a bolt too, and that is the "kosher" way to do it.
Let the flaming begin...
Author:  Doc [ Thu Mar 12, 2009 11:00 am ]
A slick damper install tool is really easy to make...
Some 3/4-16 all-thread, a nut and thick washers and damper installs are a snap.
Author:  kman [ Thu Mar 12, 2009 11:28 am ]
Post subject:  back to the shop
Thanks everyone...will keep you posted
