It is currently Sun Nov 22, 2026 12:42 am
 Post subject: Oil Talk
PostPosted: Wed Mar 11, 2009 10:53 am
This article is stolen from another board but seems to focus on flat tappet cam failure and the relation to modern oils. I appologize in advance if this topic has already been flogged but it's new info to me. Is there any truth to using diesel rated oils in our old engines? Lets hear how some of the big brains here weigh in on the subject. Oil debate
PostPosted: Wed Mar 11, 2009 11:07 am
Apology accepted.
http://slantsix.org/forum/viewtopic.php?p=140007
PostPosted: Wed Mar 11, 2009 12:04 pm
I should have known. That two year old thread was cleverly disguised as a high oil burning enquiry from Jopapa. I was more concerned with the cam failure results and break-in oil vs. everyday use oil in this guys findings.
 Post subject: BITOG Discussion
PostPosted: Thu Mar 12, 2009 7:26 am
I've been researching oils for flat tappet engines for an article I'll be writing for the Rods & Relics web site. You can read more about this topic on a discussion I started on the oil forum:
Flat Tappet Engine Oil
Another related discussion:
Valvoline Diesel Oil in Gasoline Engines
Polara Pat's first post refers back to a FerrariChat.com oil FAQ that makes case for running thinner oils in street engines:
Motor Oil Basics
