| removing oil pan https://slantsix.org/forum/viewtopic.php?t=3429 |
| Author: | Dan [ Thu Apr 04, 2002 3:48 am ] |
| Post subject: | removing oil pan |
never had to do it before, wondering if there is anything "in the way" when removing oil pan? SlantedSix225@aol.com |
| Author: | Doc. [ Thu Apr 04, 2002 10:56 am ] |
| Post subject: | Re: Removing oil pan, engine in car |
: never had to do it before, wondering if there : is anything "in the way" when : removing oil pan? The steering centerlink and the K-frame are "in the way". (at least in a A-Body car) DD |
| Author: | wolverine [ Fri Apr 05, 2002 6:42 pm ] |
: The steering centerlink and the K-frame are : "in the way". (at least in a : A-Body car) : DD the stearing link and K-frame arent a problem on my 85 d-150 but there is a bracket on the drivers side that connects the trans(mines an 833od) and the motor that when i took off my truck the oil pan had a very easy time coming out. dodgecrazy@aol.com |
| Author: | Chuck Rivers [ Sun Apr 07, 2002 6:42 pm ] |
| Post subject: | Re: removing oil pan |
Drop the idler and pitman, loosen the motor mounts and jack up the motor from the front pulley. Chuck Quote:
: : never had to do it before, wondering if there : is anything "in the way" when : removing oil pan? webmaster@omnipages.com |
