It is currently Mon Oct 26, 2026 2:06 am
 Post subject: Bad Battery?
PostPosted: Wed Mar 18, 2009 12:50 pm
While driving, my ammeter reads about +30 amps to the right all the time. It pegs when the car starts, but slowly returns to around 30 (maybe a little less). Could this be a bad battery that just wont charge all the way, or do I have a regulator problem?
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Wed Mar 18, 2009 2:22 pm
Probably a bad regulator. Bad battery usually means it won't take a charge (low current readings).
PostPosted: Wed Mar 18, 2009 2:35 pm
Could be one of those, or a bad cell in the battery. See this thread for a little more info.
Disconnect the battery, let it sit for awhile, then check the voltage across the terminals with a DVOM. If it shows closer to 10.5v than 12.6 volts, you've most likely got yourself a bad cell in the battery.
6 cells @ 2.1v each = 12.6v total for the battery
5 cells @ 2.1v each = 10.5v total for the battery.
Good luck!
~THOR~
