| Bad Battery? https://slantsix.org/forum/viewtopic.php?t=34369 |
| Author: | dusterguy225 [ Wed Mar 18, 2009 12:50 pm ] |
| Post subject: | Bad Battery? |
While driving, my ammeter reads about +30 amps to the right all the time. It pegs when the car starts, but slowly returns to around 30 (maybe a little less). Could this be a bad battery that just wont charge all the way, or do I have a regulator problem? |
| Author: | Dart270 [ Wed Mar 18, 2009 2:22 pm ] |
Probably a bad regulator. Bad battery usually means it won't take a charge (low current readings). Lou |
| Author: | THOR [ Wed Mar 18, 2009 2:35 pm ] |
Could be one of those, or a bad cell in the battery. See this thread for a little more info. Disconnect the battery, let it sit for awhile, then check the voltage across the terminals with a DVOM. If it shows closer to 10.5v than 12.6 volts, you've most likely got yourself a bad cell in the battery. 6 cells @ 2.1v each = 12.6v total for the battery 5 cells @ 2.1v each = 10.5v total for the battery. Good luck! ~THOR~ |
