| SL6 head porting question https://slantsix.org/forum/viewtopic.php?t=3445 |
| Author: | tito colon [ Sun Apr 07, 2002 10:24 am ] |
| Post subject: | SL6 head porting question |
I'm thinking of porting and polishing the head on my car. Would this benifit any performance aspects on a daily driver? If so do you have any specs so I can take to the machine shop. bigman6969170335@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Apr 07, 2002 10:42 am ] |
| Post subject: | Re: SL6 head porting helps |
: I'm thinking of porting and polishing the head : on my car. Would this benifit any : performance aspects on a daily driver? If so : do you have any specs so I can take to the : machine shop. Just grind-out the sharp edge roght under the valve seat, right where the machined angle meets the rough "as cast" port surface. Grind-off any other rough edges or bumps you see and you are set. DD |
