1 BBL gaskets?
https://slantsix.org/forum/viewtopic.php?t=34458
Author:  Rug_Trucker [ Mon Mar 23, 2009 11:04 am ]
Post subject:  1 BBL gaskets?
4 stores, zero gaskets! Can't order the gasket that goes between the air cleaner and the carb.
Even NAPA!
Author:  dietz_diggler [ Mon Mar 23, 2009 6:52 pm ]
If all you need is the gasket for between the carb and air cleaner, I would use a heavy, thick gauge paper. I use "blotters" at work on grind wheels and happened across some w/ the right Inner Dia. I just trimmed the Outside Dia. to fit, for the side screw clamp style air filter on the old stromberg 2 bbls. This style needs them. They are just thick paper, kinda like the thin paper boxes for a deck of cards, not so much like weak construction paper though.
I don't know what you running, but I don't use one at all on my 77 1bbl holley with a stock air cleaner unit.
Author:  Rug_Trucker [ Mon Mar 23, 2009 8:00 pm ]
74 1bbl Holley
Author:  bigslant6fan [ Mon Mar 23, 2009 8:06 pm ]
Post subject:  gaskets
I,ll try my NAPA store and try to get a PN for you.
Author:  mighty mouse 63 [ Tue Mar 24, 2009 8:29 am ]
I aquired several generic rubber o-rings from my local Ace Hardware, can't recall there exact purpose in life (garbage disposal?) works just fine.
Dave
Author:  Rug_Trucker [ Tue Mar 24, 2009 8:34 am ]
Hey I work at Lowes! Maybe I can find them.
Author:  mighty mouse 63 [ Tue Mar 24, 2009 8:51 am ]
I'm positive their intended for a garbage disposal :shock: , odd, my brain must have been in synch that day otherwise I would have walked right by them without a second thought :lol:
Dave
Author:  Eric W [ Tue Mar 24, 2009 9:23 am ]
I've used a gasket from a used oil filter before. A little loose and dosn't last that long, but works in a pinch.
Author:  Rug_Trucker [ Tue Mar 24, 2009 2:10 pm ]
Been using Purolator red rubber ring will look good in the engine compartment! :lol:
Got a fresh one that only went 150miles :( :shock:
Author:  mighty mouse 63 [ Tue Mar 24, 2009 2:53 pm ]
My ad hoc o-ring must be around 6 years old, shows no signs of failing, I suspect it is silicone based.
Dave
