Ignition
https://slantsix.org/forum/viewtopic.php?t=34478
Author:  68barracuda [ Tue Mar 24, 2009 12:32 pm ]
Post subject:  Ignition
This is applicable to slants as well
My 318 uses the 4 pin chrysler orange box - the coil gets very hot - and after idling a while you can not get the car to start if is has cooled down it fires first try
The Efi works 100% just no fire when hot
Is this high heat and no starting while hot indicative of a failed ballast or sick ignition or both?
OH YES while it was idling I touched the transistor on the orange box - it shocked the $#@! out of me
Am considering fitting HEI with a MSD blaster coil
Author:  SlantSixDan [ Tue Mar 24, 2009 5:50 pm ]
Getting a shock from the transistor on the ICU is normal. Don't touch it!
Coil heating up probably means internally-shorted coil drawing too much current. Measure primary and secondary resistance and compare to FSM specs.
