rear end filler plug
https://slantsix.org/forum/viewtopic.php?t=34490
Author:  daughters/scamp [ Tue Mar 24, 2009 8:09 pm ]
Post subject:  rear end filler plug
could any one tell me type of tool needed to remove the rear end cover filler plug. not sure of the rearend size but it is in a 76 scamp,225 auto. rear drums 10'' with a 4 inch bolt pattern. it looks like a cross between an allen and star.
thanks
jd
Author:  Joshie225 [ Tue Mar 24, 2009 8:10 pm ]
It's 1/2" double square on the 7 1/4. A 1/2" ratchet or extension will fit fine.
Author:  SlantSixDan [ Tue Mar 24, 2009 8:12 pm ]
And if you don't have (and don't want to buy) any ½"-drive tools, just pick up a 3" length of ½" square bar stock at the hardware store. It'll fit right in the plug, and you can turn it with an ordinary ½" wrench.
Author:  daughters/scamp [ Tue Mar 24, 2009 8:14 pm ]
thanks, i can finally get the lube changed this weekend.
thanks
jd
