| What years for NON OD A-833? https://slantsix.org/forum/viewtopic.php?t=3452 |
| Author: | Tim_K [ Sun Apr 07, 2002 8:12 pm ] |
| Post subject: | What years for NON OD A-833? |
What years did the A bodies have the non-od 4 speed? I think '76 was the first year of the OD 4 speed. Right? I found a '75 Duster for parts, and would like to know what 4 speed it has before buying. Thanks. |
| Author: | Dusteridiot [ Sun Apr 07, 2002 10:04 pm ] |
| Post subject: | Re: What years for NON OD A-833? |
: What years did the A bodies have the non-od 4 : speed? I think '76 was the first year of the : OD 4 speed. Right? I found a '75 Duster for : parts, and would like to know what 4 speed : it has before buying. Thanks. 1964(63?)-1974 should all be A-833 standards (direct 4th gear, 1964-1966 should have the 3.09 1st gear too) 1975-1987 should all be A-833OD units, I just got an iron cased A-833OD off of ebay it's from a 1975 Dart with 3.23 rear gears... good luck, -D.Idiot res0aus2@verizon.net |
| Author: | bruce [ Mon Apr 08, 2002 9:24 pm ] |
: 1964(63?)-1974 should all be A-833 standards : (direct 4th gear, 1964-1966 should have the : 3.09 1st gear too) : 1975-1987 should all be A-833OD units, I just : got an iron cased A-833OD off of ebay it's : from a 1975 Dart with 3.23 rear gears... : : good luck, : : -D.Idiot hey I wondering if that ebay tranny was a direct fourth, I almost bid against you also thought about offering to buy it off you later.Incidentialy according to the people I bought my 4spd from in woodburn it came out of a 63 signet and that was the first year a 4spd was offered.looking for another for back up. Bruce |
| Author: | Dusteridiot [ Mon Apr 08, 2002 9:54 pm ] |
: hey I wondering if that ebay tranny was a : direct fourth, I almost bid against you also : thought about offering to buy it off you : later.Incidentialy according to the people I : bought my 4spd from in woodburn it came out : of a 63 signet and that was the first year a : 4spd was offered.looking for another for : back up. Bruce I broke it open and she's an OD tranny, the vin stamped on the pad started with a '5' (1975), she was a good buy, the previous owner used oil not ATF so the guts are all minty (no chipped gears, synchros look like the day they were put in...) I think I'm going to pull the casing and tail shaft and replace them with the aluminum parts I have (like you I need a good spare for my Feather Duster). I'll keep an eye out, does yours require the ball and trunion? -D.Idiot res0aus2@verizon.net |
| Author: | bruce [ Tue Apr 09, 2002 12:35 pm ] |
: I broke it open and she's an OD tranny, the vin : stamped on the pad started with a '5' : (1975), she was a good buy, the previous : owner used oil not ATF so the guts are all : minty (no chipped gears, synchros look like : the day they were put in...) : I think I'm going to pull the casing and tail : shaft and replace them with the aluminum : parts I have (like you I need a good spare : for my Feather Duster). : I'll keep an eye out, does yours require the : ball and trunion? : : -D.Idiot mine had aball and trunion but I was able too switch( no machineing with the yoke of a78 dodge pickup top loader Bruce magicalbus@hotmail.co |
