It is currently Wed May 20, 2026 6:07 pm
 Post subject: 833 transmission
PostPosted: Sun Mar 29, 2009 6:05 pm
Hi i would like to know what transmission i have got. This is the numbers that is on the passenger side of the trans. pp8335458 The number on IBR is C13157. THANKS
PostPosted: Mon Mar 30, 2009 2:05 pm
I am not sure about the Numbers and Most Mopar Transmissions swapped/Shared bearing retainers Anyway, I think most people could give you a Very Quick answer if you post a Pic of your transmission.
PostPosted: Mon Mar 30, 2009 3:05 pm
Hi i will try to put some pic. Thanks [img]<a%20href="http://s279.photobucket.com/albums/kk142/flamed58/833%20trans/?action=view&current=IMG_4512.jpg"%20target="_blank"><img%20src="http://i279.photobucket.com/albums/kk142/flamed58/833%20trans/IMG_4512.jpg"%20border="0"%20alt="833%20trans"></a>[/img]
 Post subject: Bearing retainer size?
PostPosted: Mon Mar 30, 2009 6:18 pm
Measure the diameter of the bearing retainer or the hole in the bellhousing, that would clear things up pretty fast... with out the shift toggles in their proper position, it's kind of hard to tell, but she looks like a direct A-833 with the side plate bosses the way they are...
PostPosted: Mon Mar 30, 2009 8:01 pm
Hi it is over 5" a cross. Thanks <div style="width:320px;text-align:right;"><embed width="320" height="240" src="http://feed279.photobucket.com/flash/rss_slideshow.swf?rssFeed=http%3A%2F%2Ffeed279.photobucket.com%2Falbums%2Fkk142%2Fflamed58%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s279.photobucket.com/albums/kk142/flamed58/" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>[img]
PostPosted: Mon Mar 30, 2009 8:07 pm
I tried to put a picture on but no luck.[img]<a%20href="http://s279.photobucket.com/albums/kk142/flamed58/?action=view&current=IMG_4514.jpg"%20target="_blank"><img%20src="http://i279.photobucket.com/albums/kk142/flamed58/IMG_4514.jpg"%20border="0"%20alt="833%20trans"></a>[/img]
 Post subject: IBR 5.125"
PostPosted: Mon Mar 30, 2009 8:53 pm
She's an A833OD... unless on the rare instance that someone swapped a 1975+ A-230 5.125" IBR onto a 1974- A833 Direct box...
PostPosted: Tue Mar 31, 2009 6:06 am
Thanks
