Power Valve Selection
https://slantsix.org/forum/viewtopic.php?t=34578
Author:  DadTruck [ Sun Mar 29, 2009 7:17 am ]
Post subject:  Power Valve Selection
Picked up a Holley Trick Kit for parts to rebuild the Holley 2300 / 350 CFM carb that I had purchased (actually from Joshie 225). The power valve that came with the carb is identified as opening at 8.5 inches of vacuum. The rebuild kit has the following power valves, 8.4,,8.6,, 5.?, last digit poorly stamped probably a 0,,, Among the three power valves that came with the kit, the only physical diference I can see is the one that is a 5.? has the spool staked midway on the threaded shaft, the other two the spool is threaded about flush to a few threads shy to the end of the shaft.
for use on a mild street 225, A833, D-150, os valves, dutra duals, aussie 2bbl manifold, are there recommendation on which power valve to use ?
thanks
Author:  Rug_Trucker [ Sun Mar 29, 2009 7:47 am ]
What cam? your idle vacuum is a number that is essential.
Author:  wjajr [ Sun Mar 29, 2009 8:37 am ]
This may be helpful, look herefor what Holley recommends.
Video: here then click on: Carburetor Tuning; Play List; and Holley Carburetor Power Valve.
Author:  DadTruck [ Sun Mar 29, 2009 9:05 am ]
thanks that is helpful,
I have vacuum reading from the bone stock motor, 19 to 20 at idle,
still working out the cam selection, I'll plug one in one of the 8's, If adjustments are needed later,, at least I have been there before.
