convert slant six auto to 4 speed over drive ?
https://slantsix.org/forum/viewtopic.php?t=34629
Page 1 of 1
Author:  Delawarelife [ Wed Apr 01, 2009 7:41 am ]
Post subject:  convert slant six auto to 4 speed over drive ?
we have a 1968 Dart...our parts Dart so to speak..want to conver to to a 4 speed overdrive...will there be a crankshaft issue as far as the trans mainshaft goes..I know there is on a 440 motor..thanks!
Author:  sandy in BC [ Wed Apr 01, 2009 11:31 am ]
If you have a small V8 you are good....the slant needs a crank and bellhousing dapter
Author:  MichaelS [ Wed Apr 01, 2009 11:51 am ]
Would a 4 speed transmission out of a '72 Charger with 340 V8 swap onto a 225 slant in a '74 Dart? Were do the adapter for bellhousing and crank come from?
Author:  sandy in BC [ Wed Apr 01, 2009 2:08 pm ]
Ahhh you mean a 4 speed manual trans......
you need a slant flywheel and bell housing.
Author:  Greg55_99 [ Thu Apr 02, 2009 6:05 am ]
72 Charger is a B body. It used a different tail housing and mounted the shifter in a different spot than the A body Dart.
I don't think you can use it.
Author:  MichaelS [ Thu Apr 02, 2009 7:02 am ]
Thanks Greg, that is what I was wondering, if it would even fit.
Author:  Damraider [ Thu Apr 02, 2009 5:22 pm ]
Yes, B-body will fit, but will require some work. Check this link .
http://www.bigblockdart.com/techpages/abconv.shtml
