| Offset bracket for power brake booster available? https://slantsix.org/forum/viewtopic.php?t=34647 |
| Author: | ppsi [ Thu Apr 02, 2009 4:58 am ] |
| Post subject: | Offset bracket for power brake booster available? |
I'm looking to upgrade to power brakes from manual. It's a 65 Dart that has disk brake conversion and the booster & MS are not too expensive if it was a power disk brakes car originally but if I go to a power booster all the prices I see are-w-the "Hemi" bracket and I'm wondering if this is available as a separate part? Thanks Howard |
| Author: | GTS225 [ Fri Apr 03, 2009 1:37 pm ] |
That "Hemi" bracket is what you're looking for. It shifts the booster/M-C assembly a bit to the left to provide a couple inches clearance for the big motor. As far as I know, that is the only thing available to do what you're looking to do. Roger |
| Author: | ppsi [ Fri Apr 03, 2009 6:03 pm ] |
Do you think the "Hemi" bracket can be found by itself or does it have to come-w-a master cylinder? Thanks-Howard |
| Author: | wjajr [ Sat Apr 04, 2009 6:16 am ] |
Mancini Racing has a few they are very proud of. Other helpful brake gizmos here at Mancini. |
| Author: | ppsi [ Mon Apr 06, 2009 5:49 pm ] |
http://www.mpbrakes.com/uploads/product ... _thumb.gif This is the booster-w-the bracket from Master Power Brakes. I'm sure I could make this bracket but then I wouldn't know about the rod etc.? Thanks-Howard |
| Author: | wjajr [ Tue Apr 07, 2009 4:35 am ] |
adjustable master cylinder push rod |
