It is currently Tue Nov 17, 2026 9:08 pm
 Post subject: Eileen with new Cam
PostPosted: Thu Apr 02, 2009 6:19 am
I've done some other tuning and it looks like this cam (222@50) is going to be the cat meow. :D I've had 3-4 exhaust systems on this car and none I have liked. They where all to load and droney. This new cam sound very nice and still smokes the tires with the full exhaust. The old cam (240@50) would only burn the tires if I opened the cutout. I haven't really put it through it's paces yet, but its looking good. Had the torque converter stall change at the same time and I looks like FTI got it right. And get this NO CHARGE. I can see not charging if THEY mis the mark, but they didn't and I told them so. So for them not to charge me to change the stall when it was me that change the motor is VERY COOL.
This should likely be in a different thread, but things are looking up in the "making me happy" department.
PostPosted: Thu Apr 02, 2009 6:39 am
is this the same cuda off of youtube?
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Thu Apr 02, 2009 9:57 pm
If it's gold and it looks like it's the first time someone used a video camera, then yes it is.
 Post subject: Torque converter
PostPosted: Fri Apr 03, 2009 9:19 am
Bren,
What did they say the stall point is of the new torque converter?
Did they use V8 stall numbers or 6 cylinder?
PostPosted: Fri Apr 03, 2009 1:00 pm
Car Model: 1986 D100 /6 A833od shortbox
Fantastic car...
You thinking about Mopar Nationals at all?
 Post subject: Re: Torque converter
PostPosted: Fri Apr 03, 2009 2:14 pm
Bren,
I don't know if the numbers are V8 orI6. The first convertor was a 3200 stall and probably stalled at 3000. This converter is a 2500 and probably stalls at 2500. One of the thins I like about the two converters I got from FTI is that they drive pretty nice on the street. I can move around parking lots and slow intown driving without pushing the RPMs up to much.
PostPosted: Fri Apr 03, 2009 8:37 pm
Cant wait to see REAL track times,You deserve low 14s in my opinion,you have worked above and bee ond on this project,my hats off to you for sticking with it,good luck,Guzzi Mark
PostPosted: Sun Apr 05, 2009 9:02 am
Sounds like good progress and a nice streetable package.
