It is currently Tue Nov 17, 2026 4:28 am
 Post subject: New Exhaust Repair Tech!
PostPosted: Thu Apr 09, 2009 6:09 am
Good news on tearing down the Dart motor!.
I figured I had a cracked exhaust. Nope! The steel factory shim gasket was burned out on #2 and #3. I saw some weird rust on the head. Kind of like 1/4 panel bubbles :oops:
Turns out the manifold isn't cracked! A previous owner tried to weld the head to the manifold. I chipped the bird turd beads off with a chisel and ground it flat.
I was proud of myself getting the manifolds off without breaking any studs :)
Now to seperate the bolts holding the manifolds together without breaking them!
Gotta check into the OZ gaskets..............
PostPosted: Thu Apr 09, 2009 6:54 am
Car Model: 1967 Dodge Dart GT
wow, thats one way to seal it i guess!
PostPosted: Thu Apr 09, 2009 7:38 am
It didn't work..........
PostPosted: Thu Apr 09, 2009 7:56 am
ok, one BAD way to seal it lol...
