| Duster problems part 2 https://slantsix.org/forum/viewtopic.php?t=3471 |
| Author: | Joel [ Sat Apr 13, 2002 8:50 pm ] |
| Post subject: | Duster problems part 2 |
The consensus seems to be that I have a short in the ignition or a distributor problem that is causing a misfire in my Duster. After looking under my hood, I realized that the car's wiring harnesses have seen better days. New harnesses arent't to terribly expensive, however, Year One has an engine/forward light harness for a 1969 Valiant/Dart slant-6 and Dart 383/440. Does anyone know if this harness will work on my '72 Duster (I don't have electronic ignition). I'm also wondering how serious of a problem my cracked exhaust manifold is. Is it urgent that it be fixed immediately? jbrig@enter.net |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Apr 14, 2002 10:08 pm ] |
| Post subject: | Re: Duster problems part 2 |
: The consensus seems to be that I have a short : in the ignition or a distributor problem : that is causing a misfire in my Duster. : After looking under my hood, I realized that : the car's wiring harnesses have seen better : days. New harnesses arent't to terribly : expensive, however, Year One has an : engine/forward light harness for a 1969 : Valiant/Dart slant-6 and Dart 383/440. Does : anyone know if this harness will work on my : '72 Duster (I don't have electronic : ignition). I'm also wondering how serious of : a problem my cracked exhaust manifold is. Is : it urgent that it be fixed immediately? A cracked exhaust manifold is not a big deal, it can be noisy but it will not hurt anything. As for a bad wiring harness, unless it is completly melted with many bad wires, I would fix the one you have in the car. If possible, chase down the bad connection or short and fix that instead of replacing the whole harness. DD |
| Author: | todd m fenton [ Thu Apr 18, 2002 6:02 am ] |
Since you've indicated you do not have electronic ignition why not get a Mopar conversion kit? If your distributor is the problem it'll be changed and it is far far easier to set your timing. Cost is minimal and time is about 2 hours to install. I did the switch on a '68 Fury with 318 and was amazed at the difference. I,ve read that you should change to an electronic voltage reglator c/w a 2 pole alternator. I never did this on my Fury however and never had a problem so I don't no how necessary the upgrade to your secondary elctronics is. todd.fenton@sympatico.ca |
