| Mister Perkins Project D150 https://slantsix.org/forum/viewtopic.php?t=34763 |
| Author: | Mister_Perkins [ Wed Apr 08, 2009 5:10 pm ] |
| Post subject: | Mister Perkins Project D150 |
Work in progress. 225 slant 6. No engine mods Current list of stuff Ive put into it/done to it: Edelbrock air cleaner rebuilt carb new front rotors/pads/hub electric fuel pump new fuel lines new spark plugs new distributer/cap/rotor new master cylinder new brake lines new rear drums/shoes new coil repaired sending unit new valve cover gasket Removed smog pump, welded plug in exhaust Removed charcol canaster Hollowed cat converter Plan to do: oil frame 2" lift kit dual exhaust engine overhaul including pistons, rings. Probably bore engine out. Maybe a stroker kit New timing chain New camshaft HEI conversion Bucket seat conversion 4 Spd. manual conversion ![]() ![]() New Electric Fuel Pump ![]() Brazed two new lines in my sending unit. Tried to get a pic but couldnt get camera high enough. You get the idea though ![]() Added foglights out of an 88 chevy winabego van when we pulled the engine. installed a switchboard from it too with two inline resetable fuses. ![]() ![]()
| Author: | 56 Dodge [ Thu Apr 09, 2009 3:25 am ] |
Very Cool going to be an awesome ride! I love trucks!! |
