It is currently Thu Dec 25, 2025 7:41 pm
PostPosted: Thu Apr 02, 2009 4:58 am
I'm looking to upgrade to power brakes from manual. It's a 65 Dart that has disk brake conversion and the booster & MS are not too expensive if it was a power disk brakes car originally but if I go to a power booster all the prices I see are-w-the "Hemi" bracket and I'm wondering if this is available as a separate part?
Thanks
Howard
65 4-door Dart
70 Chrysler 300
2004 Cummins Ram 3500
1968 Dart GT Convertible-project
Chordomafoundation.org
PostPosted: Fri Apr 03, 2009 1:37 pm
Online
Car Model: '23 T-bucket
That "Hemi" bracket is what you're looking for. It shifts the booster/M-C assembly a bit to the left to provide a couple inches clearance for the big motor. As far as I know, that is the only thing available to do what you're looking to do.
Roger
PostPosted: Fri Apr 03, 2009 6:03 pm
Do you think the "Hemi" bracket can be found by itself or does it have to come-w-a master cylinder?
Thanks-Howard
65 4-door Dart
70 Chrysler 300
PostPosted: Sat Apr 04, 2009 6:16 am
Mancini Racing has a few they are very proud of. Other helpful brake gizmos here at Mancini.
PostPosted: Mon Apr 06, 2009 5:49 pm
http://www.mpbrakes.com/uploads/product ... _thumb.gif
This is the booster-w-the bracket from Master Power Brakes.
I'm sure I could make this bracket but then I wouldn't know about the rod etc.?
Thanks-Howard
65 4-door Dart
70 Chrysler 300
PostPosted: Tue Apr 07, 2009 4:35 am
adjustable master cylinder push rod
