It is currently Mon Nov 16, 2026 9:08 pm
PostPosted: Sat Apr 11, 2009 4:02 am
Enjoying all the information on this site as I'm new here. Working on reviving an 87 pu slant 4 speed manual 2 wheel drive. I'm slowly converting this over to hardware more of the 70's ie. earlier carb and switch over to hei ignition setup. When checking for a leak the other day I barely tightened the very rear exhaust manifold stud and I felt it turn so easy, not good. Sure enough it's stripped now and coolant is leaking out. I can remove the stud and the threads are fine. Tried thread sealant no good still leaks and now an exhaust leak as I can't get it tight. Is there a fix for this without pulling off the manifold? and if not is the preferred fix helicoil or tab to next larger size stud.
Thanks
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
