| Interest in Wiseco Forged pistons for the 225 rod? https://slantsix.org/forum/viewtopic.php?t=34885 |
| Author: | Rob Simmons [ Thu Apr 16, 2009 2:49 am ] |
| Post subject: | Interest in Wiseco Forged pistons for the 225 rod? |
Hey Everyone, Wiseco pistons has really been supportive of us with bringing new forged pistons to market with the "K1/Wiseco Deal". There will soon be four different bore sizes to choose from to go along with the 7.005" K1 Technologies rods. terrylittlejohn asked if there was consideration for a forged piston for the stock 225 rod application, so I thought I would start a new thread so people can chime in with interest and ideas. |
| Author: | 66aCUDA [ Thu Apr 16, 2009 5:18 am ] |
Rob I believe there will ALWAYS be interest in these pistons w/ stock rods. It would allow a good number of folks to get forged pistons than can afford the combination. Frank |
| Author: | terrylittlejohn [ Thu Apr 16, 2009 5:59 am ] |
thanks for putting this out there, i would be interested and i hope others that want a choice, even if they are twice the price of a stock replacement piston, in a better piston with a bigger bore (0.080-0.100). |
| Author: | wvenable [ Thu Apr 16, 2009 1:02 pm ] |
I think it would be great. I am however saving up for the long rod combo. Thanks, Wayne. |
| Author: | Greg Ondayko [ Thu Apr 16, 2009 2:00 pm ] |
I am all for it.. I am tossing around what Pistons to get For my Valiant project Anyway.. With The cam I am getting I will have to notch em so You can only not Hypertutic's and Cast pieces so Far. Greg |
| Author: | Mike_64_Valiant [ Thu Apr 16, 2009 3:09 pm ] |
I would be interested in a .080 over set. |
| Author: | 66aCUDA [ Fri Apr 17, 2009 5:39 am ] |
Just wondering out loud......Would it be a good thing to put some added height on the piston say.050 (over stock) to help with the compression ratio on a stock mill. Since this is a forged piece it would be easy do do and ALL of our slants have at least .150 in the hole( stock). This would help the guys that arent into working out the numbers and get them closer to "factory" specs. Remember the engine came with a .020 steel shim head gasket and your putting a composite back on, which doesnt help the compression at all. Any feedback? Frank |
| Author: | Rob Simmons [ Fri Apr 17, 2009 8:46 am ] |
| Author: | Greg Ondayko [ Fri Apr 17, 2009 1:00 pm ] |
Quote: Just wondering out loud......Would it be a good thing to put some added height on the piston say.050 (over stock) to help with the compression ratio on a stock mill. Since this is a forged piece it would be easy do do and ALL of our slants have at least .150 in the hole( stock). This would help the guys that arent into working out the numbers and get them closer to "factory" specs. Remember the engine came with a .020 steel shim head gasket and your putting a composite back on, which doesnt help the compression at all.
Any feedback? Frank Yes and no I think it depends on the application.. The low in the hole pistons work great for turbo or Supercharged stuff.. But I would like to see the pistons be Waaaay Lighter than the stock stuff.. The same thing can be accomplished by head and block milling. Greg |
