| Which block is it? https://slantsix.org/forum/viewtopic.php?t=3490 |
| Author: | Patrick Devlin [ Tue Apr 16, 2002 9:26 pm ] |
| Post subject: | Which block is it? |
Hi everybody, Been scratching my head trying to figure out which slant six block I have. The main casting number (which is a long number on the forged crank block in my car) is 030-11. The rib on the water pump mounting flange is the same thickness from the outside to the block (so it's cast crank, isn't it?) Or is it? I can't find out anything about that casting number. I know that somebody or the Doc will know for sure. Thanks. Patrick Devlin pwd22@drexel.edu |
| Author: | Doc. [ Wed Apr 17, 2002 9:25 am ] |
| Post subject: | Re: Which block is it? |
: Hi everybody, : : Been scratching my head trying to figure out : which slant six block I have. The main : casting number (which is a long number on : the forged crank block in my car) is 030-11. : The rib on the water pump mounting flange is : the same thickness from the outside to the : block (so it's cast crank, isn't it?) Or is : it? I can't find out anything about that : casting number. I know that somebody or the : Doc will know for sure. Thanks. : Patrick Devlin It is a "Later" block, (78-84) most likly a cast crank. ( I say most likly because one racer I have talked with tells me he has a "thin water pump rib" block which has a forged crank in it. . . Uhhmmm (??) Pop-off the pan and take a look, let us know what you find. DD |
| Author: | Patrick Devlin [ Wed Apr 17, 2002 7:00 pm ] |
Got this motor up in an engine stand today, but it was too dark out by the time I finished to get a good look at the crank. I'll know for sure first thing tomorrow when I get home from work. Quote:
: : It is a "Later" block, (78-84) most : likly a cast crank. ( I say most likly : because one racer I have talked with tells : me he has a "thin water pump rib" : block which has a forged crank in it. . . : Uhhmmm (??) : Pop-off the pan and take a look, let us know : what you find. : DD pwd22@drexel.edu |
