| Moog ofset bushes https://slantsix.org/forum/viewtopic.php?t=34926 |
| Author: | 68barracuda [ Sat Apr 18, 2009 12:12 pm ] |
| Post subject: | Moog ofset bushes |
Hi Gents - does anyone have the measurement of how far the moog upper control armbushes is of center? in mm/inches Please |
| Author: | wjajr [ Sat Apr 18, 2009 2:25 pm ] |
I don't have exact measurement, however the center line of the bolt hole is about 1/3 of the diameter. You can pick up about 3 to 4 degrees of caster with them. I installed a set last spring. Still need more caster, so I shall be purchasing a set of tubular upper control arms sometime. |
| Author: | Dart270 [ Tue Apr 21, 2009 6:45 am ] |
I'd say it's 3-5 mm off center. Yes, you get about 2-4 deg more +caster than stock. I run mine at +3 or 4 caster and -1 camber. Lou |
| Author: | 68barracuda [ Mon Apr 27, 2009 1:34 am ] |
Thx We have a crowd over here that started making replacement bushes Lathe turned metal pieces - cast in RUBBER R600 per set of 4 ~ $80 offset slightly more expensive COOOL |
| Author: | Dart270 [ Thu Apr 30, 2009 5:01 am ] |
I did a quick measurement on my MOOG offset bushings. They are 3 mm off center, +/- about 0.5 mm error. Lou |
