| gas reclaim line https://slantsix.org/forum/viewtopic.php?t=3494 |
| Author: | todd m fenton [ Thu Apr 18, 2002 6:25 am ] |
| Post subject: | gas reclaim line |
I recently discovered a gas line leak just ahead of rear passenger side wheel on my '80 Volare. Suspected it was reclaim line so I installed an older gas filter I had kicking around (with out the 't' for the reclaim line) No more gas smell and the motor is running great. Are there any problems I need to be aware of? Do I need an after market fuel cap to vent tank (my vent line running to the charcoal canister is still intact) I never capped reclaim line comming from tank and have had no leaks from this line, any concerns? Should I trace this line back to the tank and cap? I've been told the reclaim is to keep carb from percolating. True? todd.fenton@sympatico.ca |
| Author: | Doc. [ Thu Apr 18, 2002 1:01 pm ] |
| Post subject: | Re: gas filter in the return line |
The return system should be fine with the filter you added. I wonder if the added filter will trap anything? (there should be nothing but clean fuel & vapors in the return line part of the fuel system) DD Quote:
: I recently discovered a gas line leak just : ahead of rear passenger side wheel on my '80 : Volare. Suspected it was reclaim line so I : installed an older gas filter I had kicking : around (with out the 't' for the reclaim : line) No more gas smell and the motor is : running great. Are there any problems I need : to be aware of? Do I need an after market : fuel cap to vent tank (my vent line running : to the charcoal canister is still intact) I : never capped reclaim line comming from tank : and have had no leaks from this line, any : concerns? Should I trace this line back to : the tank and cap? I've been told the reclaim : is to keep carb from percolating. True? |
| Author: | TODD FENTON [ Fri Apr 19, 2002 9:34 am ] |
: The return system should be fine with the : filter you added. : I wonder if the added filter will trap : anything? (there should be nothing but clean : fuel & vapors in the return line part of : the fuel system) : DD Think you misunderstood. By adding older style filter I eliminated the return line altogether. I just left the old line in place from tank to engine and all seems o.k.. todd.fenton@sympatico.ca |
| Author: | Doc. [ Fri Apr 19, 2002 11:42 am ] |
: Think you misunderstood. By adding older style : filter I eliminated the return line : altogether. I just left the old line in : place from tank to engine and all seems : o.k.. Opps, I thought you added a second filter to repair the leak in the return line. Return lines are a good thing, I add them into the early cars I have to prevent vapor lock and excess pressure on the needle valve (and drip through) after shut down. Hot day vopor lock or hard restart after 5 to 10 minutes of shut down will tell you if disconnecting your return line as introduced new problems. DD |
