It is currently Sat Nov 07, 2026 2:11 pm
 Post subject: Extra coil wire???
PostPosted: Mon Apr 20, 2009 2:59 pm
While getting lost under the hood (again) of my '71 Dart /6 I discovered a wire going from the relay starter-motor pole directly to the + pole on the coil. This would give the coil a direct hit of 12 volts when the ignition key is turned to activate the starter motor. Q: Is this necessary ? Unhooking it does not effect the starting of the car. Thanks. BG
PostPosted: Mon Apr 20, 2009 3:01 pm
Only if you have hard starting.......
PostPosted: Mon Apr 20, 2009 6:55 pm
This kind of bypass wire isn't needed (or original equipment) on Mopars, because the factory wiring already has a ballast bypass that shoots full line voltage to the coil when the starter is engaged.
PostPosted: Mon Apr 20, 2009 7:06 pm
Thanks for the help. BG
