is anyone using an aussie speed intake
https://slantsix.org/forum/viewtopic.php?t=34975
Author:  mopardemon71 [ Tue Apr 21, 2009 8:39 am ]
Post subject:  is anyone using an aussie speed intake
I was wondering if anyone is usind one yet and how it fits as in relation the the master/booster in US cars?
Author:  wvenable [ Wed Apr 22, 2009 3:37 am ]
Using, no. But then my slant won't be going in an A -body anyway. We did however stick my 4 bbl manifold under the hood of Dadtruck's pickup. It looked close but looked like it would work. Dadtruck ordered his 2 bbl version and I would guess eyeballed it many times since. I would pm him and ask for his opinion.
Author:  Rug_Trucker [ Wed Apr 22, 2009 5:42 am ]
I think I saw picws of one on www.forabodiesonly.com in the slant section. Might want to contact that guy too.
Author:  mopardemon71 [ Wed Apr 22, 2009 7:54 am ]
That site is a bit busy ain't it? I'm thinking of just removing the p/b set up and going to manual disc all around. That is if it doesn't fit with the booster.
Author:  Rug_Trucker [ Wed Apr 22, 2009 9:03 am ]
Slant site at Mchat is even slower. Nice pics on FABO.
Author:  Rob64GT [ Thu Apr 23, 2009 8:30 am ]
Here is my 66 Valiant, I've measured and I don't think my manual dual master cylinder will be a problem on the early cars 63-66.
Author:  Dart270 [ Thu Apr 23, 2009 11:06 am ]
Rob,
How do you like that 390 vac sec on there for the street? Mileage, response??
Author:  wvenable [ Thu Apr 23, 2009 4:37 pm ]
Nice job on the bracket and linkage!
Author:  Rob64GT [ Fri Apr 24, 2009 12:17 pm ]
I like the 390 and this manifold package. It has better throttle response than the Clifford 4 bbl manifold I have used. The electric choke works fine, I had to buy a auto transmission adapter lever and I used a Locar AT kickdown. Over all it seams fine.
Author:  Aggressive Ted [ Fri Apr 24, 2009 2:55 pm ]
Rob,
Nice install!
Got any pictures of the transmission hookup?
What kind of vacuum readings are you seeing at idle and at cruise?
Do you feel a big difference in power?
What rear-end ratio?
What is the difference in mileage?
Author:  Rob64GT [ Sun Apr 26, 2009 10:01 am ]
Sorry no pictures of the transmission side of the kickdown. I run about 19" vacuum at idle neutral and about 15/16 in gear at about 600 rpm? Power seams good but its hard to compare because I used to have a turbo. There are 3.55 gears in the rear end. I haven't checked the millage yet but it seams like it will be good with this manifold.
Author:  Rob64GT [ Sun Apr 26, 2009 10:05 am ]
Old setup
Author:  mopardemon71 [ Wed Apr 29, 2009 9:19 am ]
Very nice sir! I am building a 74 scamp I may have a tiny bit more room than yours but not by much.
