| Electronic ignition https://slantsix.org/forum/viewtopic.php?t=34976 |
Page 1 of 2 |
| Author: | acecafe [ Tue Apr 21, 2009 9:22 am ] |
| Post subject: | Electronic ignition |
The electronic ignition box that is mounted on the drivers side inner fender of my 73 Duster is leaking.It still works but should I replace it? Where can I get one? |
| Author: | Joshie225 [ Tue Apr 21, 2009 9:32 am ] |
Find an auto parts store that sells Standard Motor Products. Ask for LX101. |
| Author: | acecafe [ Tue Apr 21, 2009 9:36 am ] |
That was fast,Thanks for that. |
| Author: | 74DartSport [ Tue Apr 21, 2009 1:02 pm ] |
LX-101 is the four pin ECU. I just bought LX-100 which is the 5 pin ECU. Both are Standard Bluestreak ECUs. Advance Auto had to order mine. |
| Author: | coconuteater64 [ Tue Apr 21, 2009 1:08 pm ] |
Either the 4 pin or 5 pin will work the same. |
| Author: | Joshie225 [ Tue Apr 21, 2009 1:31 pm ] |
Quote: LX-101 is the four pin ECU. I just bought LX-100 which is the 5 pin ECU. Both are Standard Bluestreak ECUs. Advance Auto had to order mine.
Yep, and we had a discussion about how the 5-pin is replaced by the newer 4-pin and functions just the same.
| Author: | Joshie225 [ Tue Apr 21, 2009 1:37 pm ] |
Quote: Either the 4 pin or 5 pin will work the same.
On his '73 yes, if the second resistor in the dual ballast and the associated wiring are good. Newer vehicles with the single ballast resistor cannot use the old 5-pin module.
| Author: | phogroian [ Mon Apr 27, 2009 9:18 am ] |
| Post subject: | Price difference between ignition modules |
I was about to purchase an ignition module and ballast resistor from Rockauto and had these choices: Standard Motor Products LX101T $ 20.79 Standard Motor Products LX101 $ 45.79 AC DELCO C1900Z $ 49.00 Airtex 6H1064 $ 45.00 Why is the "t" series so much cheaper? Is there any real improvement with the other brands? When it comes to ballast resistors, the Standard Motor RU12T is $2.25, compared with RU12 at $6.83. Again, what is the difference? |
| Author: | SlantSixDan [ Mon Apr 27, 2009 10:03 am ] |
"T" suffix stands for "Tru-Tech", Standards low-price/low-quality "Harry Homeowner" (or "get it out the door and sell it") brand of parts. Don't buy "T" parts. |
| Author: | Dart270 [ Mon Apr 27, 2009 10:40 am ] |
T is for toilet, and toilet starts with T... |
| Author: | Reed [ Mon Apr 27, 2009 11:16 am ] |
Quote: T is for toilet, and toilet starts with T...
Was that sung by Cookie Monster? |
| Author: | Joshie225 [ Mon Apr 27, 2009 11:44 am ] |
| Author: | Reed [ Mon Apr 27, 2009 11:52 am ] |
Quote: Quote: Quote: T is for toilet, and toilet starts with T...
Was that sung by Cookie Monster? So the "T" stands for Trash, not toilet! |
| Author: | Dart270 [ Mon Apr 27, 2009 12:10 pm ] |
Oops. Flush me... Lou |
| Author: | 00spy [ Mon Apr 27, 2009 2:15 pm ] |
All of this sesame street talk reminds me of this video on youtube called - The Count Unnecessary Censorship. Its nothing bad , but when I watch it , I giggle like a girl ,because I am immature Dave |
| Page 1 of 2 | All times are UTC-07:00 |
